map sensor?
Old Sep 7, 2010 | 10:52 PM
j.rodz's Avatar
Car: 1985 iroc-z
Engine: 305 tpi
map sensor?
Ok i have an 85 305 tpi and my question is why when i accelerate passed the mid-piont of the gas pedal the engine does not responed could it be that my map sensor has gone bad or what other sensor(s) could it be?
Old Sep 7, 2010 | 11:01 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: map sensor?
I would say tps not the map
Old Sep 7, 2010 | 11:20 PM
j.rodz's Avatar
Car: 1985 iroc-z
Engine: 305 tpi
Re: map sensor?
but the idle and slow accelerations are good but just doesnt respond in half or full throttle?
Old Sep 7, 2010 | 11:24 PM
juanillox8's Avatar
Car: TOO MANY
Re: map sensor?
thats why im thinkin tps bc u dnt have throttle response at WOT. it ur map were to be bad the car would be shaking erratically as soon as u turn the engine...
do u have any codes from the ses light?
test the tps with an ohm meter. angine off ignition switch open closed throttle should be .50 or so and WOT should be at 4
this might help...
http://www.iroczone.com/2009/10/adju...on-sensor-tps/
Old Sep 7, 2010 | 11:58 PM
j.rodz's Avatar
Car: 1985 iroc-z
Engine: 305 tpi
Re: map sensor?
ill check tomorrow and get back at u.
Old Sep 7, 2010 | 11:59 PM
juanillox8's Avatar
Car: TOO MANY
Re: map sensor?
good luck!
Old Sep 8, 2010 | 09:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: map sensor?
Originally Posted by juanillox8
it ur map were to be bad the car would be shaking erratically as soon as u turn the engine...]
If his MAP was bad he would have a big problem seeing as 85 TPI doesn't have one
Old Sep 8, 2010 | 09:30 AM
juanillox8's Avatar
Car: TOO MANY
Re: map sensor?
Haha. I can't believe I missed that
Old Sep 8, 2010 | 12:37 PM
j.rodz's Avatar
Car: 1985 iroc-z
Engine: 305 tpi
Re: map sensor?
thats funny cause at the auto parts store they pulled one out for an 85 tpi.
Old Sep 8, 2010 | 07:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: map sensor?
'85 has MAF sensor; the tube thingy on intake in front of throttle body
'90+ TPI has MAP sensor mounted on plenum
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
