is this whats causing it?
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
trying to figure out why it won't spark and found out that i don't have this piece when i removed the coil? would not having this make it not spark?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Disturbing Distributor
That looks like a ground connection for the unit.
Make sure your coil is getting 12 volts, ground, and pulse input.
Hopefully someone that recently did a coil job on that configuration of distributor will chime in and identify that part.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Happy Racing!
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: is this whats causing it?
HoosierinWA
Oct 7, 2015 10:15 AM
