Blinker wont flash, please helppp!
Old Sep 17, 2010 | 03:18 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I have a 91 camaro and since i had a few burned out stock lights i thought it would be cool to just replace them with LED bulbs. After replacing all the bulbs on the exterior with the LED bulbs i tried out my blinkers and they didnt flash, they went on and just stayed on. Someone recommended me getting a LED flasher relay and that will solve my problem. Well i bought one and plugged it in, well since there is a black ground wire coming out from it because it needs to be grounded to metal i tried grounding it. My first try it didnt work so i had a friend come look at it and the minute he connected it to a wire that had already been grounded to the car it worked, but when i turn the flasher off i still here the relay making the clicking noise. Ive tried everything and some parts of metal i put the ground wire on it wont work. This problem is frustriating me, does anyone know what can be wrong?
Old Sep 17, 2010 | 03:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Blinker wont flash, please helppp!
the problem is the front marker lights, you will most likely need to wire in resistors on the front lights.
I have the same problem on my Formula, LED's for the rear turn signals work fine but for the dual filament bulbs in the front cause them to just stay on.
I am using an Electronic Flasher unit as well.
Old Sep 17, 2010 | 03:32 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
How do i wire in resistors?
Old Sep 17, 2010 | 03:39 PM
Zepher's Avatar
http://www.plasmaled.com/tail_light_led_bulb_fix.htm
Old Sep 17, 2010 | 03:43 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thanks, where can i buy the resistors from and do i need to do them for all the lights or just the turn signal ones?
junior419
Apr 7, 2025 11:35 AM
RS Reaper
Oct 17, 2018 07:52 PM
lewandom
Oct 1, 2015 08:15 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
