High speed short
Old Sep 22, 2010 | 10:06 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
High speed short
I have this problem where about every 2 seconds my car skips a beat. The ignition system stops and my headlights begin to dim and so does my cluster lights and i see the voltage gauge start to fall. This only happens for a fraction of a second like less than the time it takes for a light bulb to turn off. can a bad alternator cause this or should I look somewhere else.
Old Sep 23, 2010 | 01:32 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: High speed short
I doubt it would be your alternator because even if that were to cut out entirely your cars battery should be able to run the car for a bit. I would look for a bad connection at one of the main power junction blocks and also your grounds.
gixxer92
Sep 1, 2015 04:32 PM
Bryan F
Aug 27, 2015 07:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
BBSDesigns
Aug 11, 2015 07:39 PM
