Non AC heater box prolems
Old Sep 23, 2010 | 10:08 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Ever since I switched to the non-ac heater box, my blower motor will not work properly. If I change blower speeds it will pop a fuse, but if it just leave it, the fan will blow. The only thing I can think of is this:
I switched from AC to non ac and the resistors were different styles, I swapped in the resistor from my ac car so I could still use my connector. I will go check, but I think I may have had the 3 pin connector, and this motor had the 4 pin.
Anybody know much about the wiring for this system? I should be getting a non-ac heater control for my interior soon.
Old Sep 23, 2010 | 12:55 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blown Away
You’re shorting one of the lines to ground due to a mismatch with the 3 verses 4 pin connector.
A heater only car has 2 resistors while an HVAC car has 3.
Using a spare headlight as a short finder, put it in series with the fuse.
Then slowly rotate the speed selector.
When the offending path is actuated the lamp will glow bright.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
