Right Blinker Light on in Dash
Old Sep 26, 2010 | 01:54 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
On the 82 Pontiac, a year a ago the right blinker light remains on in the dash. It's not brighter on the outside. If I put the right signal on, then it will flash on and off.
The parking light in the front right does not work. If I switch bulbs with the left side, it will work for that drive. After that it's back to not working.
Where do I start to fix the problem?
Old Sep 26, 2010 | 09:19 AM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: Right Blinker Light on in Dash
Have you checked your right blinker socket for corrosion or wear. If it checks ok check for power to one of the pins with parking light on (might be a bad connection in socket)
Old Sep 26, 2010 | 10:52 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Transmission: TurboHydramatic 700R4 4 speed autom
Axle/Gears: ?
Thats good. Corrosion is what F'ed mine, looked fine. I replaced the bulbs and cleaned the connections and worked fine. Also remove the housing inside vehicle and clean off corrosion, grease, dust, etc.
Jk_Under
Sep 2, 2015 10:59 PM
Pilotrick50
Sep 2, 2015 12:48 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
