Power Window Relay Location
Old Sep 26, 2010 | 09:33 AM
djkarma5's Avatar
Car: 91 Z28, 02 GA GT, 88 Firebird(sold)
Engine: 5.0, Supercharged 3.4
Transmission: 700R4, Hydramatic 4
Axle/Gears: 3:73
i just got this 91 z28 and the windows dont go down. the fuse was beat and i changed that but cant locate the relay, can anyone show me with a pic or a good description which one it is as there's like 3+ big relays i've found so far. 2 behind brake master cylinder and i see one near the battery. also everything else power works, the locks and hatch pop are powered so i dont think its a wiring issue, plus they worked when i first looked at the car but maybe from overcharging the batter it killed the relay n fuse....? any help appreciated.
Old Sep 26, 2010 | 10:45 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Power Window Relay Location
They don't have relays. If the motors are not functioning, and the switches are good, and the wiring is good, then it's the window motor itself. They don't use relays because they have built in circuit protectors inside the motors - if there's too much draw (ie motor not working), ten the motor itself shuts down and resets in a few minutes. There's a great article here about swapping out motors without removing the regulators from the door - I've done it this way on several cars and it works great.
https://www.thirdgen.org/forums/body...tall-easy.html
Old Sep 26, 2010 | 11:30 AM
djkarma5's Avatar
Axle/Gears: 3:73
so overcharging the battery could of blown the fuse and motors?
Old Sep 27, 2010 | 12:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
The window system doesn’t use fuses.
There is a circuit breaker in the fuse block for it labeled
WDO.
Also, good info from
camaronewbie.
Before you replace the motors, you want to know if they’re good or bad.
So now it’s time to troubleshoot.
Check the breaker in the fuse block for 12 volts in and out.
If the breaker is OK use a test light
(the type for testing for voltage, not a continuity tester)
or voltmeter to see if you have power at the
pink wire going to the switches.
Is there power there?
If yes, see if power gets to the motors when rocking the switches.
Happy Racing!
I Didn’t Wreck, The Track Moved
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
