Engine Scanner
Old Sep 30, 2010 | 06:36 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Engine Scanner
Can anybody recommend me a descent engine scanner to run and clear codes on my 89, 5.7ltr. tpi transam gta. Is there a ALDL cable out there with USB to connect to your laptop, with cd, (software) ?
Thanks in advance.
Old Sep 30, 2010 | 07:35 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine Scanner
If all you want to do is see stored codes then jumpering A and B on the ALDL connector will make the Chk engine light flash the codes.
For a Vette but same for F-Body
http://www.corvettebuyers.com/c4vettes/codes.htm
On a '89 disconnecting the battery clears the stored codes.
Cable to connect to ECM
http://www.aldlcable.com/
and use free software like TunerPro on a laptop.
http://www.tunerpro.net/
Lets you monitor the engine sensors in real time as it is running
Old Sep 30, 2010 | 09:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Engine Scanner
Best scan tool for the money is a paperclip and this: https://www.thirdgen.org/service-eng...ht-error-codes
To clear codes, disconnect the battery for a few minutes.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Electro_X
Aug 19, 2015 07:59 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
