older steerin wheel two lights stay on
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
airbag lite i read jus take bulb out. well security lite stays on too. and it has a no vats switch in it its been replaced do i just take that bulb out too?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: older steerin wheel two lights stay on
Did you bypass the VATS on the dash side? If this is on the 1991, you do have VATS, and if you installed an older model column without VATS, the security light will burn and the car won't start unless you bypass the VATS on the dash side.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
car starts and runs fine. i didnt put wheel in it. like that wen i got .
Fronzizzle
Mar 18, 2019 08:29 PM
