pull down hatch
Old Oct 11, 2010 | 05:30 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
pull down hatch
im rewiring my car and i have the pull down hatch and i want to know if i t is easyer to rewire it or replace it with a non pull down?
Old Oct 11, 2010 | 05:33 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: pull down hatch
If you have an '86 pulldown unit. Overall the wiring is pretty simple. Are you rewiring after a fire or rodent issue?
http://www.top-downsolutions.com/Doc...structions.pdf
This guide should be more than enough to get you through it with pics and stuff. It covers rebuilding the motor but between it and your general Haynes or Chilton Wiring diagrams it shouldn't be too bad.
Old Oct 12, 2010 | 11:07 AM
Engine: 355
Re: pull down hatch
well thanks for the link but i know my pull down work cuz it was working before i started rewiring the car.
my problem is that that all the wires that go to the back of the car end at the side of the driver seat. my switch is not wired up or anything i have no wires under my dash or a fuse block.
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
