Need some help with wiring in a diff alternator and cts swap
Old Oct 12, 2010 | 08:02 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I had a 2 wire connector before on my alt, new one has only one red wire coming out, old 2 wire had a red one coming out similar with a connector loop, and the other wire going to the harness not sure how to wire it up...
Also, I am converting from a coolant switch(for idiot light) to sending unit(for real gauge) and the sending unit has only one prong on it, much like the fan relay or either oil pressure unit, the old switch had a 2 wire connector on it...
Need to figure this crap out so I can drive my car finally...its like all it needs atm..
Old Oct 12, 2010 | 02:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash Rehash
It’s better to use the original type of alternator however if you must use what you have the one wire simply goes to the battery +.
Use an ohmmeter to trace which wire from the harness goes to the dash OverTemp light.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
eightsixseven
Dec 16, 2024 01:50 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
