92 z28 runs great cold no power warmed up
Old Oct 17, 2010 | 09:05 PM
gallingerchad's Avatar
Car: 1992 z28
Engine: 305 tpi
this z is making me nuts, runs great when its cold, after 10 mins of driveing it cant get full throttle, smells funny, it wont take gas, when i stop at a light i gotta be easy on the gas just to get the car moving, if i shut it off for like 2 mins its fime for about 2 mins if that then right back to no power, help
Old Oct 18, 2010 | 09:05 AM
JoeNooch's Avatar
Car: 1991 Z28
Re: 92 z28 runs great cold no power warmed up
Does the car stall at all? Especially when warm and you go full throttle?
This is what my car was doing a few years back; ran good cold, when it warmed up the car got VERY rough, when I hit the gas it would stall and would not start back up until it cooled down.
Turns out, the fuel injectors were bad. Get a multimeter, measure the resistance of each injector. If I remember correctly, measuring 14-17 ohms means the injector is ok. Anything less than 14, the electrics are shot and the injector is garbage.
Old Oct 18, 2010 | 05:13 PM
southbay08's Avatar
check your injectors,and your temp sensor also.
Old Oct 18, 2010 | 08:02 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Sounds like it doesn't want to be in closed loop.... check O2 sensors maybe? A lot of things could cause your symptoms so just start with the basics (make sure its had a recent tune up as well). Maybe get a can of carb cleaner and look for a vacuum leak too.
Old Oct 19, 2010 | 09:53 AM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
i had that problem with one of my blazers, it was the coolant temp sensor on mine,
there are 2 sensors one for the gauge, and the one for the computer i needed the second one.
when i scanned it with winaldl it showed a coolant temp of about -40.
it was 70 out that day.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
