Tailight help for 89 Firebird
Old Oct 18, 2010 | 12:46 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
I have an issue with the tailights of my 89 Firebird. I have No taillights/parking lights - nothing to the rear, execept I have have power to the hatch pull down. Any ideas??
Old Oct 18, 2010 | 09:11 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Tailight help for 89 Firebird
Forgot to add that I have checked the fuse, and it is good.
Old Oct 18, 2010 | 12:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tale About The Tail
Put the lightswitch in the “park” position.
There is a connector at the left rear of the car which you gain acces to by opening the hatch.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the brown wire on both sides of that connector.
If you have no power there, you have a break from that connector to the headlight switch.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 18, 2010 | 12:50 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
I'll try that tommorrow!
Old Oct 19, 2010 | 05:37 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
I bought the car not log ago from someone who left somethings unattached
So I found out it was the body ground by the power hatch motor
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
