how to install autometer gauges
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I just went through instruction for all of my new autometer gauges for my LT1/T56 swap. i am using a new stand alone harness.
the harness has all the engine connectors for all the sensors.
the autometer gauges comes with new senders for some the gauges. if i remove the harness plug and sender and install the autometer sender and wire it to the gauge then what happens with the connectors on the engine harness? does the computer not get any information from these senders now (temp, oil, etc...) and do i just tuck away the harness connectors that will not be loose?
help would be much appreciated. thanks.
I have autometer speedometer, tachometer, voltmeter, boost, oil pressure, oil temp, water temp, and fuel level.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Engagement Party
The ECM receives no information VIA gage senders.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
ambainb
Apr 25, 2016 09:21 PM
86IROC112
Aug 17, 2015 02:00 PM
