Starting issues 86TA
Old Oct 20, 2010 | 11:39 PM
Sandman22's Avatar
Car: 86 Trans Am
Hi everyone
I'm sure this is stupid and I should gotten it right away, but I am gona ask anyways because I'm having trouble. I have an 86 trans am tpi 5.0, and I cannot get it to start without a jump. But it starts every time with a jump, just sounds like barely though, its sort of a fast clicking start and then it runs like a champ. No other issues. Is there some wiring issues I should look for other than the obvious. I would love to just say replace the starter, but if it starts every time with a jump the starter must still be working right? Could this be an ignition problem? Below is the current condition of the starting/charing system:
It has a brand new battery (fully charged) I already took one back because I thought it was bad and an older alternator (but still charges at 14.54V tested with my volt/ohm meter). Any ideas you have are greatly appreciated, I would love to get this thing back on the road after this winter!
Old Oct 21, 2010 | 01:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dropped Voltage, But It Didn’t Break
OK because you said voltage is 14.5 the problem seems to be that voltage not getting to the starter.
Do a voltage drop test.
Connect one lead of the meter to the
+ post of the battery and the other lead to the starter S terminal.
Attempt to crank, then note the reading on the meter.
Then repeat the test after you move the test lead from the S terminal to the B terminal.
If you see more than a half volt indication on the meter
(which means voltage drop) clean or replace those defective connections.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 21, 2010 | 02:55 PM
Sandman22's Avatar
Car: 86 Trans Am
Re: Starting issues 86TA
Appreciate it NINA, I will try this weekend if I get some time
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
