Where to purchase replacement electrical connectors?
Old Oct 24, 2010 | 05:27 PM
89RedIrocZ28's Avatar
Anybody know a good online source for gm electrical connectors? I am in need of quite a few for my 86 vette, 89 iroc, and even 1 for my 99 TA. Yes I could easily fix these things with aftermarket crimp on connectors and such but I really strive to do electrical repairs as close to factory as possible. I like my wiring to all appear factory origional even if it isn't. I know it's a little **** but nothing bothers me more than butchered wiring harnesses. I'm sure everyone out there who has ever purchased a 3rd gen knows exactly what I'm talking about, the disrespect some of these cars receive just bothers me.. Sorry for the rant.. Can anybody point me in the right direction?
Old Oct 24, 2010 | 05:37 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: Where to purchase replacement electrical connectors?
Try your GM dealership I still get all my connectors from them.
In some cases you may have to solder the wires then use heat shrink around the soldered wires(in the case of molded connectors)
Old Oct 24, 2010 | 05:49 PM
Yeah, gonna have to take a day off and go to my old job (GM Dealer) where the parts guys still give me my employee discount. The only reason I havn't yet is do to lack of time, my only day off is sunday Good call on the solder n heatshrink tho, that's one of the 3 ways I consider a proper repair. The other being the crimp connectors with the heatshrink covering, I like to use them for repairs in tight areas and of course tuck them neatly back into the factory loom to hide the repair In cases when the actual connector is still in good shape u can always repair the terminals, however the issues im dealing with are basically missing the factory connectors completely. Ever see wire nuts on an automotive application?
Old Oct 24, 2010 | 06:59 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
i just wired up my ls6 swap and i got all of my connectors form www.pcsconnectors.com they are alot cheaper than gm dealers even with the discount they carry any thing you will need
Old Oct 24, 2010 | 08:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Much more often than I'd like.
I've always just bought replacement connectors at the local "real" parts store, like NAPA or whatever. A google search for "weatherpak" or "weatherpack" or something similar should turn up a few dozen online sources, though.
Old Oct 24, 2010 | 09:38 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
rockauto.com
oemhq.com
tpiparts.net
if you go to ACDelco's website they have a list of ALL of the connectors GM uses , it gives you the PN#'s too.
Old Oct 24, 2010 | 11:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.eficonnection.com/eficonn..._pigtails.aspx
http://www.eficonnection.com/eficonn...rPigtails.aspx
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
