Firebird tachometer not working…
Old Oct 25, 2010 | 07:41 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Hello everyone,
I have a 1991Pontiac Trans Am with a non-operating tach. It does not move at all. No warning, one day just did not work at all when I started the car.
I know a lot has been said on here about calibrating a Camaro tachometer by means of a resistor (“https://www.thirdgen.org/forums/el...meter-fix.html (90-92 Tachometer fix....)”), but I am fuzzy as to first - whether or not the fix is the same for a Firebird and second - whether or not a non-operating tachometer could be caused by the same resistor issue as a faulting reading tachometer. All other gauges work. So prior to just replacing the tachometer circuit board, other suggestions are welcomed.
Any and all feedback is greatly appreciated!
Thanks,
Jim
Old Oct 26, 2010 | 06:55 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Re: Firebird tachometer not working…
Any and all suggestions appreciated here guys... I'm scratching my head...
Old Oct 26, 2010 | 10:11 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach Is No Good For Speed Over A Mach
Make sure the signal is still getting to it from the distributor.
It would be nice if it’s just a loose or dirty connector.
Before you replace the board you can make sure the D’Arsonval movement is still good.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 26, 2010 | 01:09 PM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
I have checked the coil and distributer connections and they appear fine (so long as no wires are broken). What is the "D’Arsonval"?
Thanks,
Jim
Old Oct 26, 2010 | 01:43 PM
NINÅ's Avatar
Transmission: 765R4
The mechanism which moves tach needles either are D’Arsonval or stepped motors.
In either case you can test the movement before swapping the board hoping it will fix it.
After isolating the unit from the driver board gradually apply voltage to it to see if you get any movement.
Happy Racing!
jhawkeye
May 25, 2022 06:33 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
