Are these volts normal?
Old Nov 1, 2010 | 04:21 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Trying to figure out why It won't start.
I'm getting:
12.4 volts from the battery.
11.90 volts from the ignition wire connecting to distributor with key "on".
7-8 volts from the ignition wire while cranking.
are any of these numbers out of range? Problem is no spark.
Old Nov 1, 2010 | 09:30 PM
0pyders's Avatar
Re: Are these volts normal?
got done testing the coil...
primary resistance was normal but couldn't pick up a reading for the secondary resistance. Does this mean that I need a new coil?
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
