Wire through Firewall
Old Nov 1, 2010 | 05:19 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
Where can i feed some 18 guage wire through the firewall on my 87' base model camaro?
thanx
Old Nov 1, 2010 | 06:11 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Wire through Firewall
If you can't feed it through with some existing wires you may have to drill your own hole. Wherever is convenient and doesn't hit anything on the other side and where you can easily find the wire when it's pushed throughl. It's a good idea to use a grommet. Maybe close to where existing wires go through.
Old Nov 8, 2010 | 03:49 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
behind the master cylinder is a large grommet you can use.
Old Nov 10, 2010 | 12:46 PM
Pocket's Avatar
Car: 91 Trans Am
Under the column is the cruise mini-harness grommet with lots of room. On the pass side you can feed a small handful through the antennae grommet
Whatever you do be sure to insulate the wires where they pass through steel with at bare minimum a rubber grommet
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
86IROC112
Aug 17, 2015 07:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
