passenger brake light
I have a 89 trans am. My passenger side brake lights will not turn on when the brake is pressed however the driver and 3rd brake lights do come on. The headlights and rear running lights work fine. I have new bulbs. Any suggestions.Thanks.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: passenger brake light
Really the only place the problem could be is in the wiring harness behind the taillights. First place I would check is the splice between the driver's side wiring and the passenger's side wiring. If the splice is good check the sockets.
Car: 1992 Camaro RS
Different circuit, same harness in the rear. What about the reverse light on that side? Sounds like you may have a bad harness.
