More interior lights
Old Nov 5, 2010 | 07:06 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Has anybody added more interior lights. I was thinking of adding some above sail panels pr around that area. Just curious if anybody has done this. Would I just tap into the wire that supplies dome light?
Old Nov 5, 2010 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: More interior lights
Or if you simply want more light, install LED's in your dome light. Though the following link is about an install in an overhead console, the set-up would be the same.
https://www.thirdgen.org/forums/inte...-overhead.html
JamesC
Old Nov 5, 2010 | 10:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've added LED's to my interior. I have kick panel LED's that come on/off with the opening/closing of the doors, as well as come on with the park lights (used 3in LED strips up under dash). I also have rear floorboard LED's that function the same (used the LED windshield washer lights mounted in the rear corners of the center console). I also have a LED inside the center console that lights with park lights (used a license plate bolt LED). Then I installed a 36 LED panel in the dome light as well which lights up the whole interior ALOT when I turn it on (not connected to the doors).
Old Nov 5, 2010 | 11:13 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Any pics??
Old Nov 6, 2010 | 03:10 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Also the HVAC lights and hifter light suck. Have they always been like this. Only lights up half of HVAC controls. Also all my bulbs on gauges work, EXCEPT ones behind speedo. Any guesses to why?
Old Nov 6, 2010 | 03:48 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
blown bulbs.
Old Nov 6, 2010 | 04:29 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
So are they like old school christmas lights where if one is blown rest don't work. Because every single other bulb light except the few behind the speedo.
Old Nov 6, 2010 | 11:13 PM
Engine: L31 350
no, just the blown ones
Old Nov 6, 2010 | 11:47 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I used 2 tractor trailer LED licence plate lights which have 5 LED's in each and wow the dome light is bright now. Also if you want the lights to come on when the door is open I suggest the dome light as it will be closer to the sail panels
Old Nov 7, 2010 | 12:29 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Then none are blown because I put ones that were behind speedo in other spots and the worked. Would dimmer switch effect them?
Old Nov 7, 2010 | 12:38 AM
Engine: L31 350
what i was saying is if one bulb is blown the rest will still work, it sounds the the lights behind the speedo are blown from age and use, take your gauge trim peice off and lower your steering column, there are two bolts under the dash you can remove in order to lower the column ( 13 mm i think), after that is done just slide your gauges out. check the bulbs behind the speedo to see if they are loose or blown, this has happen to me before, my driver side turn signal indicator bulb was lose so it wouldn't turn on, i tightened it and it was fine. if they are blown take them to your local parts store to pick up replacments, should only be a few dollars at most.
Old Nov 8, 2010 | 12:46 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I think he's saying that he put the suspect bulbs in a different location and they worked. If that's the case then clean the all the contacts on the circuit board. You can use a little rubbing alcohol or a pencil eraser.
Old Nov 8, 2010 | 05:04 PM
Engine: L31 350
yeah i see what your talking about now, must have read through his post to fast or it must not have registed in my brain what he was saying.
Old Nov 8, 2010 | 07:41 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah I just tightened them all and got most to work. I also got a new dimmer switch and I think that may have helped because mine has some bad contacts inside because I had to giggle it to get lights on dash to work also.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
