altenator killer?
Old Nov 6, 2010 | 09:07 PM
infared337's Avatar
altenator killer?
Please help I'm lost. Something is causing my altrnator to die and not charge. I have replaced the battery altenator twice. Batt cables and still no charge. I have no idea where to turn next. I've checked power to all the wires connected to the altenator and they test ok. The only thing that has not been replaced is the charge wire going from the alt. To the pos battery. Is it possible that may be the problem? I changed the fuse attached to the charge wire but I don't know what the other two connections are off that same wire. Can any one help? Thanks n advance. 89 trans am 305tpi
Old Nov 10, 2010 | 12:47 PM
Pocket's Avatar
Car: 91 Trans Am
Re: altenator killer?
Check the fan fuse under the dash. GM put the alt and fan relays on the same fuse for some reason
cowansauto
Apr 3, 2025 12:51 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Magman
Sep 12, 2015 10:43 PM
fasteddi
Sep 10, 2015 09:32 AM
InfinityShade
Aug 22, 2015 08:00 PM
