led gauge lights, but i have a problem.
Old Nov 6, 2010 | 11:14 PM
palmer90rs's Avatar
i put led white 4x 120 degree 194 led lights in my gauges on my 90 rs, there is only 4 bulbs.
i made sure all the bulbs worked and also put power to the cluster for the lights to make them work,
but i put the cluster back in and i can only get the right side two bulbs to work.
what is going on?
also for some reason the lettering on the gauges looks greenish, how do i fix this?
Old Nov 8, 2010 | 12:51 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: led gauge lights, but i have a problem.
The leds you bought may be polarized meaning they only work if plugged in in one directions, flip em around and see if that helps. Also clean the contacts on the circuit board with rubbing alcohol or a pencil eraser. The gauges are greenish because they're tinted yellow and the led's are making it look green. Not much you can do about it. BTW I'm pretty sure there are more than four back light bulbs in the cluster
Old Nov 8, 2010 | 04:37 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
also make sure your cluster is plugged in all the way, are all your gauges working?
Old Nov 8, 2010 | 09:35 AM
palmer90rs's Avatar
well if i take the cluster out and put power and ground to it i can light the lights up and if i take the light socket out i can make the bulb light up so i know they are working.
there are only 4 bulbs that light the gauges, the others are for like service engine and stuff like that.
and yes all my gauges are working fine, the speedo is a lil off but still working, and its all plugged in at the back of the cluster, and they were working before the leds so idk
Old Nov 11, 2010 | 12:25 AM
palmer90rs's Avatar
any other ideas guys? i really would like to see all of my gauges since most of my driving is at night
GTAman
Mar 15, 2019 11:40 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
db057
Sep 4, 2015 07:57 AM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
