New starter but no start
Old Nov 11, 2010 | 10:41 AM
DRock89RS's Avatar
Car: 1989 RS,1991 Z28
Engine: TargetMaster 350, L98 350
Axle/Gears: 10 bolt posi 2.73s, and 3.23s
i just put in a new starter and the starter itself works fine but the car wont turn over with the key. earlier this year i put in a new ignition cylinder, ignition switch and now the starter. when i jump it itll start but not with the key. i know its not the VATS since i installed the new cylinder so any help woiuld be appreciated..
Old Nov 11, 2010 | 02:03 PM
Brads RS's Avatar
Re: New starter but no start
Check and make sure that you are getting power through the park neutral switch on the shifter. I have had the contacts get worn out not allowing it to start unless you jump it.
Old Nov 11, 2010 | 03:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by DRock89RS
. when i jump it itll start..... i know its not the VATS
Starter enable relay operated by the VATS module could be faulty also.
Relay can be bypassed ; you still have VATS shutting down the injectors for security
Typical GM starter circuit with VATS
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86Base
Aug 8, 2015 01:34 PM
