under dash wiring,driverside 85 camaro
Old Nov 7, 2010 | 05:00 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
i have an 86 model iroc with a complete dash out of my 85 iroc, the columns in everythings hookd up, but there are two grey connectors under the dash,that go down the rocker toward the rear tail lights, and the two wires for the fuel pump bundled with it, one has 7 prongs the other has 6, my column, brakeswitches and everything in the dash is hooked up what do these hook to?
on right under the column, less than a foot from the c100 bulkhead is also a black connector that has 11 wires/prongs that has no place to hook, and a single pink, a single brown and a single orange, they all are dangling, i am at a loss, this is the exact column and dash from my previous car, no cuts or splices have been made, any help would be outstanding i have pics, not sure how to paste them
Old Nov 7, 2010 | 05:34 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Re: under dash wiring,driverside 85 camaro
no pics but here are the wiring on the 2 grey plugs and the black one: 7 prong plug pink,pink,red/white,white,black,tan,orange
6 prong plug blue,yellow,brown,yellow,drk green,lite green
11 prong black plug black,white,tan,orange,white,blue,
pink,lite green, brown, dark green, yellow
the 6 and 7 prong plugs are hooked to the white wires for the door jambs, and tied into the harness going to the rear for tail,brakelights, the 11 prong, is under the dash close to the fusebox and column harness
Old Jan 2, 2011 | 01:54 PM
Saav28's Avatar
I've got a male connector plug with four wires (Pink/Blk, Gray/Blk, Gray, Blue) under the dash on the driver side and cant find where it connects to, im not sure if its for my turn signals since my front turn signals dont work. Its a 1988 Iroc
Old Jan 9, 2011 | 04:03 PM
genes88GTA's Avatar
anybody know where the starter enable relay on a 1988 firetird GTA L98 is located. its suppose to be left kick panel but only thing there is the power door lock relay.
Old Jan 9, 2011 | 04:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
genes88GTA:
1) should start your own thread instead of hijacking another where there's no common question.
2) There is no starter enable relay on a 1988 car - they were part of the VATS system that wasn't in place until 1989. If your key doesn't have the VATS pellet on it, then you don't have one.
3) Welcome to TGO! function here works really well - try it before posting.
Jorlain
Aug 24, 2022 05:11 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
