ecu removal
Old Nov 7, 2010 | 09:27 PM
509iroc's Avatar
ecu removal
i need to remove my ecu and harness in my 87 irocz. ive gave it a little effort and couldnt get the connector on the inside of the passenger fender is a real pain. ive tried looking through treads and using the search. havent found anything.
Old Nov 9, 2010 | 10:30 AM
509iroc's Avatar
Re: ecu removal
oh yea i forgot to mention that i dont want to remove my fender. i will if i have to. but rather not. so anyone have a url they can send me or something? i tried again last night with no prevail.
Old Nov 9, 2010 | 02:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ecu removal
Try removing the ECM with the harness still plugged in, then remove the harness from it - gives you more room to see/work, as there are tabs on it that need pried up to remove the harness. The only thing that holds the ECM in place is one tab that you push, then it's velcroed into it's slot - just push the tab and pull down on the unit.
Old Nov 12, 2010 | 01:19 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: ecu removal
I think he's trying to remove the entire harness. I wish I could tell you for sure, but I think you're probably going to have to pull the fender. I've looked at mine since I want to do some spare wire removal this winter. I'm not to excited about pulling fenders either, but mine were developing some rust and I have some clean ones that are going on instead.
Old Nov 14, 2010 | 11:31 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: ecu removal
If you remove just inner fender then you can reach up to harness.
Old Nov 14, 2010 | 02:11 PM
509iroc's Avatar
Re: ecu removal
i succesfully removed the ecu and harness. it was real easy. pulled a panel off the interior and the inner fender. never had to remove the fenders like i heard from so many places. thanks for the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
