Cs-144 on a sbc?
Old Nov 10, 2010 | 05:39 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Cs-144 on a sbc?
Ive seen the posts on fitting the cs144 on tbi and tpi motor but what about the sbc?
Is it possible to fit one on there?
What car that are most likely to be at the junkyard came with the cs-144?
Old Nov 11, 2010 | 01:52 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cs-144 on a sbc?
TPI and TBI are SBC's
Is it possible to fit one ?
What type Alt are you replacing?
Bottom of page
http://www.extreme4wheelin.com/tech/...ators/tech.htm
Old Nov 11, 2010 | 03:55 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
I meant the older v belt style mounting with the big bracket sbc not the serpentine belt setup.
I do have a underdrive setup,so I am running a 5 groove belt.
I have a 10si on there now.
Old Nov 12, 2010 | 05:38 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Just change the pulley on the alternator. If you are replacing one of the old style SI alternators, the CS-144 should have the same bolt spacing.
You would want to look for a CS144 alternator with 140amps from the factory. I bought mine from a 1996 Chevy Caprice with the 5.7 engine, but you can get one from a 1996 Camaro (5.7L) and also a 1995-1996 Cadillac engine would have one.
The differences are small, but important from which car you get it from. The clocking of the alternators are different in respect to where you would plug the connector in. The Camaro alternator has the plug on the bottom, the Caprice facing the passenger side. The Cadillac has a threaded upper bolt hole whereas the Caprice does not.
Here is a informative thread:
https://www.thirdgen.org/forums/elec...ed-up-alt.html
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
