89 Firebird battery issues
Old Nov 18, 2010 | 04:20 AM
aariccc's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
alright so the car was running off the battery when i first got it i cleaned the neg grounds and got a new battery and the battery gauge was staying around 12, 13 for about 2 weeks and now the battery is completely drained and the car wont start unless its jumped but dies back down and stalls after there disconnected iam not sure what it could be maybe a fuse? or alternator?
Old Nov 18, 2010 | 08:22 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 89 Firebird battery issues
check the alternator, take it off and take it to your local parts store like autozone and have them check it. also do you have a sound system in your car? that could also drain your battery.
Old Nov 18, 2010 | 10:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
pull out the alt and have it checked like emokid mentioned. also grab a multimeter and check to make sure there's no breaks (continuity test) in the cable going from the alt output to the battery.
sounds like power's not getting to the bat from the alternator, as you should be 14v or higher when the engine's running.
Old Nov 18, 2010 | 03:45 PM
aariccc's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
yea i wonder if it could be the linkable fuse from battery to alternator because my buddy kit the back of the alternator on accident and it sparked i wonder if that would of blown anything, the car wasnt running it was off when he did it
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
