temp gauge
Old Nov 18, 2010 | 03:01 PM
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
temp gauge
ok here is my problem.i turn the key to start the car and the temp gauge goes all the way up. then the damn thing sticks there when the car is running.i have to hit it like the fonz to get the thing back down.so here are my questions. 1 is this normal to go up like this durning starting. no other gauges do this. and is this gauge seperate in the gauge cluster,so i can replace just that gauge? thanks for the help!!!!!
Old Nov 19, 2010 | 09:05 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: temp gauge
The gauge is not "separate". However, you can check the a couple of things. Disconnect the gauge wire from the sending unit on the engine and turn the ignition on. The gauge should go to the max position. Plug the wire back in and the gauge should now start to move down. If This doesn't happen, you have a wiring issue. If it functions correctly during this process, you may have to pull the gaugle cluster and make sure the connections are solid. Worst case, you can replace the motor/actuator behind the gauge face but you run the risk of breaking needles and possibly other things.
Old Nov 21, 2010 | 12:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: temp gauge
yes
yes
https://www.thirdgen.org/forums/post...31-post13.html
https://www.thirdgen.org/forums/post...37-post14.html
Old Nov 21, 2010 | 07:11 PM
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
Re: temp gauge
Thanks for the hugh help deadbird.there is so much info here sometimes you can't find just what your looking for.but now I have the info I need. Thanks bro! And good luck with all the projects!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
