washer pump?
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
washer pump?
the hoses go through the firewall into the cabin, there was a lot of bad wiring done under the dash so i want to know where the pump is i don't want to pull on the wrong wires, any ideas?
Re: washer pump?
No, but they go through the firewall to the cowl...
The pump is in the bottom of the wiper motor. There's a little metal clip that has to be carefully removed, then the pump just pulls out the bottom. New pumps come with a new clip that snaps in place to keep the pump from falling out. The pump is like $20 at parts stores.
Car: Trans am
Engine: 78 350
Re: washer pump?
they looked a little low for that? there are two hoses from a T from the jug that go to the firewall fairly close to ether of my two squirters... does that sound right?
Car: Trans am
Engine: 78 350
Re: washer pump?
85, they are on the firewall fairly close to being behind the squirters and they are 4-6 inches down from the pinch weld at the top of the firewall
a lot of my car was messed with before i got my hands on it
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: washer pump?
The hose for my rear washer/wiper goes into the cabin.
JamesC
JamesC
