problems on HEI install
Old Dec 6, 2010 | 02:48 PM
tpiwrangler's Avatar
I am putting a large cap Hei dist with coil on top, on my sd tpi using a custom harness and am having some issues wiring it up because of the custom setup in a Jeep wrangler. I was able to wire up the 4 wire to the engine harness, its the other three wire plug, and on the coil other then the Tach terminal that im not sure about. This is the first time i had done one of these and did some searching but couldn't find the right info.
Thanks for your time
Old Dec 6, 2010 | 11:52 PM
Re: problems on HEI install
can anyone help me
Old Dec 7, 2010 | 01:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
3 wire plug from dist base plugs into cap behind the 2 outer terminals.( can see pink + brown wires in pic below )
Outer terminals have
Pink 12V ( hot ) wire to BATT terminal
White ( tacho) white goes to TACH terminal
Old Dec 7, 2010 | 10:42 AM
Brads RS's Avatar
Pink 12v is switched ignition hot while in, key on and and cranking position.
Old Dec 7, 2010 | 10:46 AM
wow Im a freakin retard, never thought that plug goes on the coil.
thanks alot guys. I love this forum
Mike
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Fronzizzle
Aug 17, 2015 02:52 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
