FAN RELAY CONNECTOR
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
FAN RELAY CONNECTOR
Hi, where can i buy a plug for the fan relay ?????
Mine burned up !!!!!
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Re: FAN RELAY CONNECTOR
Try checking auto parts stores, IE: Autozone, Oreilly's, Napa etc. They should have it.
Car: 1989 Camaro RS
Engine: 305 TBI
I had the same problem, I ended up going to the junk yard for it. They gave me that and a good relay for $20 I believe it was.
Which style do you have?
I keep a bunch of ovals in stock
If you have the flat kind, make sure the rest havent done this. If they have, Id cut these off and solder the newer oval type on
ITS THE OVAL ONE I NEED, 2 of them would be cool...let me know if u would sell me 1 or 2 ...NEED FAST ..lol
THANKS !!!!!!!!!!!!!!!!!!!!!!!!
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I used a old square fuel pump relay (the 2nd one in your picture). I hit the junkyard a few months ago in Mexico and I managed to pocket a connector for free. Works great, especially because the wire is a bigger gauge. I can take a picture to see how i did mine tomorrow if you'de like.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is another option ...
A relay is a relay, they are all pretty much the same. You can get a new relay and plug for it, and wire it into the existing wires (which you'd have to do with a stealwership or used plug anyway). Any 5 prong relay (or is it 4 prong, I always get it and the fuel pump relay confused) will work.
the fuel pump is the square one !!!
So if anybody has one , please let me know ...its not that i dont want to pay for it , just not 70 bucks !!!! LOL
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
I'd try calling Dorman for a reseller. Here's a link to their catalog:
http://www.dormanproducts.com/flipbo...nductTite.html
Look under Terminals.
Man, they have almost everything ....just not this oval plug..lol
Thanks tho,,a lot of good stuff in here !!!!!
FormulasOnly
Sep 10, 2015 09:07 PM
MikkoV
Sep 9, 2015 04:25 PM
