Need help stumped
Old Dec 9, 2010 | 10:16 AM
projectcamaro83's Avatar
Need help stumped
Finally got my 83 camaro running and all lights work except the turn signals, the hazards work but not the turn signals was reading another thread to see if others had same problem and found some useful info,but still blinkers don't work changed out the the flasher on the c-clamp and still nothing any kind of help would be greatly appriciated
frustrated in texas
joe
Old Dec 13, 2010 | 09:16 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Merely Drive Straight
With the key in RUN, turn signal stalk in the left turn position, use a test light to probe the light blue wire out of the turn signal switch.
Is there power there?
If not, replace the switch.
If there is power there, make sure it gets in and out of the connector located near the lower right of the steering column.
Then make sure power gets in and out of the large connector located near the left front of the dash below the relay bracket.
From there it goes to the lamp on the front of the car.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
