HELP
Old Dec 12, 2010 | 09:52 PM
fast z28's Avatar
Car: 1983 camaro z28
Engine: 305 HO.
Transmission: A5- 5 speed
Axle/Gears: 3.73 gears
HELP
i was wondering how to wire up a electric fan to a 2 way switch (2 prong), i am also wondering how to wire up fog lights? please respond asap. thanks.
Old Dec 14, 2010 | 07:50 AM
Brads RS's Avatar
Re: HELP
You will need to use a relay. Depending on the size of fan and location of relay will determine the correct relay.
For example a small square relay available from most parts stores, that would handle most fans/lights would be wired as so.
Normally open relay
Terminal/ connection
85/ + from switch
86/ ground
30/ battery +
87/ + to fan
Same rules apply to fog lights. rocker switches normally cant handle the load from fans or lights and will burn up. Let me know which relay you will be using and i can tell you the connections.
Old Dec 14, 2010 | 08:11 PM
fast z28's Avatar
Engine: 305 HO.
Re: HELP
i havent gotten a relay yet, what kind of one should i get, sorry for the questions, havent wired up anything with a relay before. how many amped relay should i get, maybe find me a link. thanks for your help, Tyler
Old Dec 15, 2010 | 07:45 AM
Brads RS's Avatar
Re: HELP
This is the one that i would use
http://www.larryselectricsite.com/st...3&productid=56
on the bottom of the connector are letters next to the proper holes and your wires will go as follows
A= Fused Battery hot (25 or 30 amp fuse depending on fan size).
C= not used
D= chassis ground
E= power to fan
F= power from switch
Use at least 12 gauge wire for battery power and fan power, use 16 or 18 gauge wire for your switch, use a fused ignition source for the power for your switch, and of course you will need to ground your fan also. You will need to use pliers to "crimp" the terminals on and i would also solder them. The battery hot i would get directly from the battery, don't splice on to something else. Get an inline fuse holder from your local parts store for the fuse or larrys also sells an ATO fuse block that will work (its under replacement connectors). Hope this helps.
Old Dec 15, 2010 | 12:08 PM
fast z28's Avatar
Engine: 305 HO.
Re: HELP
thank you very much, this is very helpful, il get back to you if i have any problems or how she works when im done. thanks for your help,
Tyler
