Still burning up flashers even after column swap.
Old Dec 16, 2010 | 10:05 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I got my column swapped for the tilt issue. They said we'll see what happens with the turn signals and high beams not working after the column is swapped. Worked fine for a while but now my high beams are back to not working so well, unless I tilt the wheel down some, which I'm assuming I can adjust at the switch.
But I can tell the turn signal flasher is now burning out again because when I flipped the switch last night, I had no flasher until I tried again a little later and it worked. Eventually it does this and just stops working all together. I really don't want this back in a shop because I'd much rather do this myself. Any ideas on where I should start?
Old Dec 17, 2010 | 09:39 PM
84z350crate's Avatar
Car: 84 Z28
Re: Still burning up flashers even after column swap.
check the switches on top of the column. theres the high beam switch there and the ignition switch there
$750 L98
Feb 1, 2025 02:25 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
85 Jimmy
Sep 30, 2015 07:56 AM
usafirebird
Sep 29, 2015 11:58 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
