Fan problem
Old Dec 21, 2010 | 10:05 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Fan problem
I have a 91 camaro with dual fans. Since i bought the car i found that with turning the key to the ON position both fans will be running. The fans never go off unless the cars off, they run all the time when im driving, and when i just have the car to the ON position using the battery. I have no idea whats wrond with it but i do remember the guy that had it before me said that he did some wiring to the fans. The mechanic at GM told me that someone wired the fans to be on all the time. I want to fix this problem so they come on when they should and the dant wayste my battery when im just listening the the radio. What would fix this problem?
Old Dec 21, 2010 | 06:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fan problem
Yep - another hacked fan wiring job.
For starters, you can turn the key back one notch (ACC) - that should run radio without running fans.
Then, you'll have to get into the wiring and figure out what's been done, undo it, and redo it correctly. Wiring Schematics here:
http://www.austinthirdgen.org/index.php?pid=19
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
