ignition switch
ignition switch
can the ignition switch down the coulum go bad and if so will it look like the vats is to blame i did the key i did the bypass so it must be the ign. sw. base. any way of checking it to see if it is bad. and how do you get the cable off the back of it.newbie needing help.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ignition switch
Yes .
I told you that in you that in your other starter question
https://www.thirdgen.org/forums/post...124-post2.html
If the switch contacts are bad then you don't have 12V going into the starter circuit
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ignition switch
You have to get the switch off the column with the cable still attached, then you can flip it over and you'll see two little tiny screws that hold the cover over the cable end, take those screws off, seperate the switch covers, and then the cable comes out - it's a real PITA. There's a pin inside that holds the cable, I think it fell out when I did mine. It's hard to describe, kinda just have to dive in carefully and you'll see. Good Luck!
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
