still won;t crank
Old Dec 17, 2010 | 11:26 AM
cspawnkillu's Avatar
still won;t crank
the problem started when i put a steering column in and after i put it all back together. i found out and got the new key to the right resistance.but still all i get dash and radio come on but no pump or stater. i think i need to bypass the VATS but no clue, so please somebody tell me in step by step how to do this. i have a part car that i am pulling from.
Old Dec 17, 2010 | 02:09 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: still won;t crank
When you replaced the column, was there an orange looking wire that was really a sleeve with two skinny white wires inside and a plug at the end hanging out the bottom? That is the lead from the key cylinder that has to plugged into the plug for the VATS module or you get what you're getting. Should be a little plug with two wires, one white with black stripe and one purple with white stripe coming out of lower firewall around bottom of column. Plug these together and if all wiring is intact it should work now. If you have nothing to plug in there that's where you do the bypass. Do a search on here or check the technical articles section for details
Old Dec 17, 2010 | 02:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you replaced the steering column with a pre-1989 column, the ignition cylinder won't have VATS in it - so getting the right resistance key is no good since there would be no contacts in the key cylinder to read the pellet. Bypass instructions here: www.thirdgen.org/vats
Old Jan 5, 2011 | 10:41 AM
i put a 91 bird coulm in it but now it will not crank i did something but i dont know what to look for it i pluged it all back but no luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
Formula_88AE
Sep 3, 2015 01:47 PM
