VATS question!
Old Dec 30, 2010 | 03:28 PM
dawg9967's Avatar
VATS question!
When I buy the resistor, what watt should I get. 1/4 1/2 1/8. Which one?
Old Dec 30, 2010 | 03:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Size Doesn’t Matter . . . . . uhhhhh At Least Not In The Circuit.
It doesn’t matter.
Those fractions refer to the wattage dissipation of the resistor and there is not enuff wattage in that part of the circuit to matter.
Therefore choose a resistor of a size to make it easy to connect.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Dec 30, 2010 | 10:30 PM
dawg9967's Avatar
Re: Size Doesn’t Matter . . . . . uhhhhh At Least Not In The Circuit.
[QUOTE=NINÅ;4773000][CENTER][B][COLOR="NAVY"]It doesn’t matter.
THANXS!!!!!!
Old Jan 4, 2011 | 03:17 PM
cspawnkillu's Avatar
Re: VATS question!
Hi i,m trying to get my 92 firebird to start i did the bypass and it still wont crank. what is or is not your car doing? the security light comes on but does not blink , checked starter it works. checked battery o.k. somebody said check p/n switch i think it is under shifter,changed starter enable relay it is under the kick plate driver side. If you had any luck getting it started please let me know.
Old Jan 4, 2011 | 03:38 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Re: VATS question!
It might be the VATS unit itself then. You'll have to buy a VATS bypass module off the internet and solder it in if your vats is broken.
Old Jan 4, 2011 | 05:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS question!
Originally Posted by cspawnkillu
it still wont crank. checked starter it works.
But have you got 12V coming out of the Ign switch when key in start?
Switch could be faulty sending no power to starter circuit
Have you checked for 12V at the relay , the P/N switch / starter solenoid when key in start position
Could a have bad wire / bad connection somewhere
Old Jan 4, 2011 | 05:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: VATS question!
VATS Bypass module only supplies correct fuel injector enable signal to ECM.
You still have to manually bypass the starter enable relay so it wouldn't help with his problem
Old Jan 5, 2011 | 01:25 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: VATS question!
does anyone know of a good write up to bypass the VATS as I am going to be putting my 355 t56 in my car soon and would need to know how to either bypass it or completely eliminate it all together. Thanks
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
