Where is the third gen camaro fuse box?
Old Jan 2, 2011 | 09:28 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
So my power antenna is broken and keeps trying to lower my antenna even after the keys are out of the ignition. Ive resorted to disconnecting the battery until I can get time to fix it but I was wondering if I could just remove the stereo / power antenna fuse and it should stop, right? If I can do that temporarily, where will I find the fuses?
Old Jan 2, 2011 | 09:33 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: Where is the third gen camaro fuse box?
Not so quick, the power antenna does not get its power from the radio.
The radio just switches it on and off.
Turn the tires all the way to the right.
Take off the passenger side wheel well liner.
You will find a connector going to the antenna motor - just disconnect it.
Old Jan 3, 2011 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Disconnect the relay, which is under the pass side of the dash. IIRC, mine was in the general vicinity of the ECM.
JamesC
Old Jan 3, 2011 | 06:56 PM
Kwijybow's Avatar
Engine: Carb'd 305
Thanks a bunch for the advice! I had to turn the wheels all the way to the LEFT not the right, but the idea was sound. Snipped the wires (couldn't find any actual plug to disconnect) and now I still hear the switch "ticking" when I start and stop the car, but the motor doesn't do anything. Thanks again!
Old Jan 3, 2011 | 07:13 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Also, to answer your question, the fuse box is located under the drivers side dash. There should be a plastic piece that you can remove and the fuse box is right there.
Old Jan 3, 2011 | 08:48 PM
JamesC's Avatar
Originally Posted by Kwijybow
...now I still hear the switch "ticking" when I start and stop the car, but the motor doesn't do anything. Thanks again!
That's the relay.
JamesC
Old Jun 14, 2017 | 09:05 PM
Fitmeetsshan67's Avatar
Hello all, sorry that I'm replying to an old post, but I'm kinda stumped. I've recently purchased an 1989 IROC-Z project. It currently doesn't run but does turn over. I believe that it's not getting fuel. My guess is that it's probably the fuel pump, but I'm checking the wiring first before I shovel money towards the pump. I checked the leafs to the fuel pump relay and determined that it's not getting power and now I'm double checking the fuses. My problem is that I don't know how to drop the fuse box. I've already taken out the screws towards the rear of the fuse box but I can't seem to find how the fuse box actually comes down.
Old Jun 14, 2017 | 11:55 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Check the fuse by the battery under the hood if your not getting power to the fp relay.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
BRoss99
Aug 10, 2025 05:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
