Speedo repair non mechanical q's with vids
On my 87 firebird v6 Automatic. I have been trying to diagnose whats up with my Speedometer.
Video of my speedometer issue
1/08/2011 problem found http://www.youtube.com/watch?v=veq_DSlMsss
My speedometer still resives power but most of the time now it does its own thing. It used to work fine. Everything in this car is stock. the front tires are a little bigger then factory, but still read correct for at least 6 months with these tires, rear tires I belive were stock size. The other gauges work fine and the trip and odometer work.
In trying to diagnose this, I discoverd the 87 bird does not use a cable.
I replaced the VSS in the end of my transmission a couple of times to no avail.
I am seeing that some use a Buffer box? and I see one listed in my wiring diagram. If I have one, can u point me in the direction to test it.
Is this my buffer box? vid of what could be my buffer box? (ended up being my cruise control module)
found the buffer box, Yellow box pickybacking on the ECM
Also been having a hard time figureing out what to look for in buying a new Speedometer Head. going to look at a speedo at oriellys tommorow. ( I do want to get a speedo that reads above 80/90 mph)
This is what my instrument cluster looks like
Speedometer out of cluster does the needle itself pull off?
Car is my daily driver, and up for inspection.
Any direction apreatiated
Re: Speedo repair non mechanical q's with vids
I purchased a 140mph cluster out of an 87 trans am.
now I have a 140 mph displaying speedo
But it is still broke
Thanks. least instrument cluster and VSS should be good so far.
Any direction on articles how to check if the wiring is all good. Someone said they have signal bleed over in there VSS signal wire in one there build.
. But it is still broke
couple Places ive found for wiring diagrams so far
click and scroll down to see Wiaring diagrams posted by 87v6Bird
heres Autozones, believe have to login and possible search through repair guides
Believe I have these in my Chiltens as well.
Wires to 4 out buffer box
buffer box details < fills in the gaps for the buffer box
1 connector starting from bottom up had wire colors
Blk/white stripe
Green/ black stripe
Red
Brown
Pink/Blk
next connector
Yellow
Purple
A look inside my Buffer box at the board inside
Blk/white stripe
Green/ black stripe
Red
Brown
Pink/Blk
next connector
Yellow
Purple
Light green with black stripe to cluster
brown to ECM
pink/blk battery
blk/w ground
red cruise control module
seperate connector from VSS
yellow
purple
In manual for diag it says to test the light grn/blk to ground and with ignition on should see 12v at disconected connector that would connect to buffer box.
I do not get correct voltage reading here. Is it that the power goes into cluster, then through the circuit board on the cluster, power comes back through this light grn/blk wire to the buffer?
vid of my lt GRn/blk wire test. http://www.youtube.com/watch?v=B6KkBKw9x_M
I Just unplugged the battery positive and negative cables completly.
IGN off
Ohms meter set for continuity
Connector unplugged from buffer box. with and without instrument cluster installed.
Red Lead in buffer connector at Lght GRN/Blk from instrument panel
Black lead in buffer connector at Black/Wht Ground
Result: Continuity True
http://www.youtube.com/watch?v=2bIUGxLRf_w
Black lead in buffer connector at pink/Blk 12V from battery through ign/fuse
Red Lead in buffer connector at Pink/Blk 12V from battery
Black lead in buffer connector at Blk/Wht ground
Red Lead in C1 connector at Cluster Lght GRN/Blk to Buffer Box
Result Continuity True
Black lead in buffer connector at Light Grn/Blk from cluster
Result: Continuity FALSE http://www.youtube.com/watch?v=Icobegi0Vbc
Red Lead in buffer connector at Lght GRN/Blk to cluster (same result if replaced with power and ground for this example)
Black lead in buffer connector at Brown to ECM
Black lead in buffer connector at Red to cruise control
brown to ECM
pink/blk battery
blk/w ground
yellow
purple
IGN off
Found the Issue WOOOOOOOOOO
but yeah prolly the wiring harness at the cluster, rubbed cut its was through into the wires and grounding at the metal that was cutting through them looks like.
Another WOOOOO
Now to see if I can get closer and to figure how to repair them
Another WOOOOO
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm having a very similar problem..Speedo its jumping all over even in park. ok, might be onto something..I tested at the buffer between the black/white tracer(ground) and the Pink/black tracer(power) and got 12V which is correct. When I test between the black/white tracer(ground) and the Green(gauge cluster), I should also get 12V but only getting 10V.Then I disconnected the battery, tested the black/white tracer to ground and all good I have continuity..Here's where it gets funky, I tested the Pink/black tracer to ground and it ALSO showed continuity..So it's looking like the Pink/black tracer is shorting to ground correct?? If So where does that Pink/black tracer come from so I can try to find the short.
Car: 89 Formula 350
I was lucky enough to have TGO member Pocket send me over a VSS diagram. My cars an 89 and think his diagram was for a 92? Anyway from following the diagram the Pink/Black tracer runs from the VSS buffer to the Fuse Block... So I must have a short between those areas..Seem like I'm on the correct path? Does the 12V Pink/black tracer go anywhere before the fuse block or is it a homerun direct to the fuse block? The diagram I have isnt very detailed
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Homerun !
The pink wire with a black tracer branches off to various locations.
A short to ground in any of those locations will blow the GAGES fuse.
If that fuse is blowing disconnect one branch at a time to determine the location of the short.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Happy Racing!
