what about a V8 tach in a v6?
Old Jan 4, 2011 | 08:01 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I'm so sick of my tach reading too high... I even bought a NOS one, and it was worse than the one I have now. It reads 4000 RPM at highway speeds.
Yesterday I picked up a V8 cluster just to get the Speedometer (with a working trip odometer) It has a nice looking V8 tach in there, but what would happen to my tach and oil pressure readings if I put it in my car? would it read 33% lower than normal?
Or...if you have a v6 tach and want to swap me it for this v8 tach, let's do it
Old Jan 10, 2011 | 11:36 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tachy Response
If the “V8 tach” you have is OEM you can calibrate it for the V6 by replacing a resistor in the dash.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
