full wiring harness
Old Jan 4, 2011 | 11:59 AM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
full wiring harness
so i got a 86 camaro that i was going to make a race car but i change my mind unfortunately i did it little to late cuz i got rid off my wiring harness. so my question is how hard would be to find a full wiring harness from bumper to bumper?, and how much should i pay for one? in the engine comparment is going to live a tpi turbo
Old Jan 5, 2011 | 04:55 PM
Pocket's Avatar
Car: 91 Trans Am
Re: full wiring harness
Source a replacement from a JY
Since you're starting from zero, why not shoot for the newest year 3rd gen. 90-92s had the most updates and are more consistent for all engines
Also, Id suggest building a new engine control harness to support the turbo TPI. The stock ECM (any of them) wont like boost. Updating to LSx PCMs will handle it just fine and you're already going to be in the wires
Old Jan 5, 2011 | 10:15 PM
Engine: 355
thanks pocket for the help so your saying get complete wiring harness from bumper to bumber for a 90-92 car and pick up a compleate ls1 engine harness for my engine?
will the ls1 harness work with a 383 or 400 tpi engine i say this cuz i havent disided what im building yet.
other thing there is a ls1build for the 3 gen flooting around in the for sale section you think i should pic that up or start from scratch
Old Jan 6, 2011 | 05:12 PM
Pocket's Avatar
Car: 91 Trans Am
Not a LS1 engine harness. Build a custom harness to use a LS1 PCM to control the TPI
https://www.thirdgen.org/forums/tpi/...-opinions.html
Using all the wiring from your donor car makes the job easier
Old Jan 6, 2011 | 06:36 PM
Engine: 355
there is 21 pages on this sounds like is a good thing to do but do you know if there is any step by step on this harness build?
Old Jan 6, 2011 | 07:14 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/post...009-post4.html
Not this particular harness, but the procedure is the same. Only thing different from the LS1 harness is it uses 8 indiv coils where you're only using one. That one gets wired to coil #1's position. Dont forget the firing order change from LS1 to SBC on the injector numbers. Its a 2,3 and 4,7 swap
Old Jan 6, 2011 | 07:34 PM
Engine: 355
excuse all the questions but i dont want to go out and buy a harness than be wrong one and have to get other one my question is do i pick up a 6 or 8 cyl harness. and one more time sorry about all the stupid quiestions lol but i dont want to freeze my axx off and than turn around and go back out there and do it all over
Old Jan 6, 2011 | 08:21 PM
Pocket's Avatar
Car: 91 Trans Am
3rd gen half van be V6 or V8, makes no difference. The part that makes them EFI gets cut away
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
