Coil Resistance?
Old Jan 6, 2011 | 06:08 PM
DacMan's Avatar
Coil Resistance?
Does anyone know what the limit for acceptable resistance for an hei coil is, my Hanes manual says that it should be zero or close to zero? What the hell does that mean? I'm getting a reading of 1.2-.9
Thanks, DacMan
Old Jan 10, 2011 | 12:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Resistance Is Futile
The resistance is about .3Ω for the primary.
Your .9Ω to 1.2Ω might be imperfect contact among the leads.
Therefore if you have no spark you should check voltages.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the primary of the coil when the key is in the RUN position.
Is there power?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
apie2546
Oct 16, 2016 02:24 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
