91 Z28 tach issue
Old Jan 11, 2011 | 08:17 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
91 Z28 tach issue
i looked at wiring diagrams and got a head ache so i am going to ask and maybe someone has the answer. the tach works but is way off...at idle it reads 4000 RPM even though its not running at that. it goes up and down as you rev it like it should just not correctly (if that makes sense) when the car is off it goes right to zero. when the ignition is on engine off it reads zero, at soon as it starts it reads 4000. what would cause this? coil? pickup? i am at a loss and it annoys me
Old Jan 14, 2011 | 07:55 AM
Car: 91 Trans Am
Engine: 355 TPI
Re: 91 Z28 tach issue
anyone?
Old Jan 31, 2011 | 03:59 PM
malibuz16's Avatar
Look here:
https://www.thirdgen.org/forums/elec...meter-fix.html
Old Feb 1, 2011 | 09:10 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
86T/A_Ram_Air,
I would have to say it's the pick up coil that's giving an inaccurate reading.
Old Feb 1, 2011 | 05:09 PM
Car: 91 Trans Am
Engine: 355 TPI
Originally Posted by chevypower91
86T/A_Ram_Air,
thats what i thought but if you look through the thread posted above it appears to be the tach board, i guess i could replace some stuff before i tear apart the cluster, i would hate to modify a tach board for no reason if something else is actually the problem
Old Feb 1, 2011 | 09:51 PM
benny42's Avatar
Car: 1986 Corvette
Axle/Gears: 3.07
Test the tach board resistor chip. It is an easy fix, & seems
to be a pretty common failure. I fixed mine last weekend by
the info in the sticky.
deracer
Apr 11, 2016 12:04 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Regal105
Aug 23, 2015 03:45 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
