whats this box?
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
whats this box?
Behind my dash I have my yellow buffer box and a large metal ecm box, what is the smaller metal box. It shares wires with the other to. I thought the buffer was my VSS so whats the other one called and what does it do? All three are next to one another..
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: whats this box?
Vss bugger box, ECM, maybe a cruise control module, or a Vats module?
Re: whats this box?
Two metal cases are ECM and SIR. Smaller one with yellow connectors/tape is SIR aka airbag
The rear defrost relay also has a metal case but is significantly smaller than the others
