Need help changing headlights
Old Jan 18, 2011 | 08:47 PM
Clean87IROCZ28's Avatar
Car: 1987 IROC-Z
Hey I recently bought an 87 IROC-Z and for some reason the guy that had the car before me put some REALLY dim, crappy lights on it. I ordered some new lights today and I should get them tomorrow and I was wondering what is the easiest way to change headlamps? Please help. I can't drive at night until I get the new lights installed.
Old Jan 18, 2011 | 11:32 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Need help changing headlights
Hello Clean87IROCZ28!!
Spray some penetrating oil on the screws that hold the trim ring on, let it soak for a bit, then have a go at it!!
These screws can be a real bear to get out!!
Use a long handled screw driver for better grip, and no damage to the headlight pocket!!
Once the screws are removed, be careful pulling the trim rings off, as they can scratch the plastic in the headlight pocket, if you are not careful!!
When reinstalling the trim ring screws, put some protectant on them for easier removal at a later date!!
Are you sure that the PO even changed out the headlights, as the lights will tend to dim after a "few" years!!!
P.S. The trim ring has two screw holes with slots at the bottom, and two holes at the top, it is possible to just loosen the bottom ones, and remove the two top ones, and then remove the trim ring, but that causes the trim ring to be bent when removing it!!
I would remove all four screws!!
Old Jan 19, 2011 | 10:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had good luck loosening (but not completely removing) the lower ones, since they can be a pain to get at like Dan said. Completely remove the upper 2 and you should be able to swing the bezel down and out of the way enough to get the headlight out.
Old Jan 19, 2011 | 11:21 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The trim ring screws are close to the corners. The screws in the centers are for adjusting the beam - leave the centers alone.
Old Jan 20, 2011 | 05:19 AM
Car: 1987 IROC-Z
Thanks for all the help I got them in and they work great.
GTAman
Mar 15, 2019 11:40 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
