Fixing my speedometer gauge...
Old Jan 21, 2011 | 07:41 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
All of my gauges on my dash seem to not be working properly. first of all I think the speedometer gauge is off because it says i am going 80 but it feels like 90, and my gasoline gauge marks at half a tank and I just filled up in gas. I just wanted to know how to fix most of the gauges on my dash especially these two main ones, thanks!
Old Jan 21, 2011 | 09:39 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
You can check the speedometer with GPS or a scanner.
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 90Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Jan 21, 2011 | 09:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fixing my speedometer gauge...
Where the speedo is concerned, do as Nina suggests because "feels" like isn't very accurate. Should there be a problem, check the link to follow:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Feb 13, 2019 12:51 AM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
