Turn signals and headlights don't work! Help!
Old Jan 25, 2011 | 03:09 PM
JoshuAA1990's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 5.0L TBI
Axle/Gears: 3.08
Let me start with this; I bought a 91 Camaro RS a few months ago. Didn't run, so I've been slowly fixing it up. I've ran into some electrical issues that I just can't figure out. From really looking at the car, it looks like someone started to turn it into a drag car. There's wires everywhere, and I don't know what goes where.
Issue number 1 -- The headlights worked on lowbeams when I got it. Now, they don't. So I checked that little white switch that I've read so much about.. Only to find that it's not even hooked up. What color wires are supposed to be hooked up to this? I'm also gonna tear into the dash and see how the light switch is wired. Issue 2 -- the turn signals do not work. They also used to work when I got the car. Now, they don't. No lights on the dash, no lights outside, nothing. My emergency flashers work, both on the dash and outside. I've read about people switching the two flashers out to see if it's a bad flasher.. Where is the turn signal flasher? I know where the emergency flasher is, but I can't find the turn signal flasher. Also, I noticed that there's two empty fuse spaces below the emergency flasher. I don't remember what they're marked as, but are there supposed to be fuses in there?
Please help! All this is making my brain hurt.
Old Jan 25, 2011 | 03:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Brighten Up The Day By Dimming The Lights
The colors are yellow for the power input, tan for the lo-beam output, light green for the hi-beam output.
The turn signal flasher is clipped onto the fuse panel, as delivered from the factory.
However if it has been replaced it might just be hanging in the maze of wires.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Ghettobird52
Jul 5, 2024 11:18 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
