HVAC Controls lights?
Old Jan 31, 2011 | 08:25 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
This may be a stupid question, but are the HVAC controls supposed to light up at all? I have a 1992 Camaro RS.
Old Jan 31, 2011 | 08:56 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: HVAC Controls lights?
One #194 light at the far right side. You might be able to get to it from behind if you pull out the radio. HVAC controller is a little more difficult to remove since it has a cable that attaches it to the temperature door. In any case, once you remove the plastic trim from the radio/HVAC pod, there are 4 7mm screws that hold the HVAC panel in place, you may be able to pull it out far enough to access the twist socket that holds the light.
Old Jan 31, 2011 | 08:57 PM
chevydrvr's Avatar
Thanks!
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
